Activity Forums Adobe After Effects Problem with ‘Save frame as file’
  • Problem with ‘Save frame as file’
    Posted by Kim Taylor on February 9, 2013 at 1:19 pm
    I have never used this feature before, but I want to start using it because it sounds like a very useful addition to my workflow.
    However, when I try to output a single frame from this command, I get the following error
    After Effects warning: Cannot output to this format because it is not currently installed.
    (39::99)
    I looked up this warning and I think it’s something to do with the output module. I’m on a PC, perhaps it is trying to output in a mac-only format?
    In any case, I have no idea how to change it. I would have thought the output module details would be in the render queue, but after giving me this error nothing gets added to the render queue. How can I fix it? (Resorting to using screen captures in the meantime!)
    Kim Taylor replied 13 years, 6 months ago 3 Members · 4 Replies
  • Vishesh Arora
    February 9, 2013 at 2:33 pm
    Kim
    Which command are you using? Is it ” Cntl + Alt + S ” ?
    By default it is set to Photoshop document which should not create any problem.
    Try deleting your Pref file. Hold ” Cntrl + Alt + Shift ” as you start AE and choose OK.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Howard Matthews
    February 10, 2013 at 3:14 am
    Go to Edit > Templates > output templates to set the default file type for rendering. It’s not exactly the most intuitive dialog box, but that’s where you tell AE what format you want renders and still frames to default to.
  • Kim Taylor
    February 10, 2013 at 5:13 pm
    Thank you for your reply, I wouldn’t have thought to look in there!
    I changed the setting for Frame Default and the error has gone away, however now I have a new problem: When I execute the command to ‘Save Frame to File’ it appears in the render queue, but when I press Render, nothing happens, even after waiting for some time. I’ve tried all the different presets to see if it makes any difference but no luck. Curiously, the default ‘Photoshop’ setting now works, and doesn’t give me an error.
    Any idea why it’s not rendering? It seems like such a simple command yet so hard to make it work :s
  • Kim Taylor
    February 10, 2013 at 5:27 pm
    Sorry, I’ve just established that the rendering problem is due to an separate issue. I’ve managed to make it work fine now.
    Thanks for your help
