Activity Forums Boris FX Particle Illusion Problem with resizing windows (artifacts)
  • Problem with resizing windows (artifacts)
    Posted by Lee Shapiro on March 31, 2011 at 5:25 am
    I originally had an ATI Radeon HD 5850 graphics card, but I was having trouble with two software programs with it. One was e-on software’s Vue and the other is particle Illusion. With pI, whenever I would resize any of the window panes within the program, it would leave “video echos” or artifacts and would leave part of the original window size where it was before I resized it. (So it would create a double or triple border for one window pane)
    I changed video cards to a GeForce GTX 460, it solved those problems, but it also caused my computer to crash at least once a day, especially when playing videos. I tried everything, including updating all the latest drivers, setting my BIOS to the factory settings (No overclocking), but I still wasn’t able to figure out why I kept getting the BSOD.
    So now I switched back to the Radeon 5850, and I still have the same problems with those two software programs.
    Has anyone else experienced this problem, any known work-arounds (besides buying a new card – which I can’t afford right now)
    Thanks for any advice or suggestions,
    Lee
    Alan Lorence replied 15 years, 5 months ago 2 Members · 1 Reply
  • Alan Lorence
    March 31, 2011 at 11:47 am
    That’s a redraw problem, and is a video driver issue for sure.
    If the latest drivers for your Radeon don’t fix it, then try a slightly older driver. You want to use the latest non-beta driver that’s available.
    To confirm it’s a driver issue, use the particleIllusion “run with software rendering” Start menu option.
    Alan.
    http://www.wondertouch.com
