Activity Forums VEGAS Pro Problem with rendering to Android on Sony Vegas 13 Pro
  • Problem with rendering to Android on Sony Vegas 13 Pro
    Posted by lai maidan on September 10, 2023 at 2:28 pm
    Folks, I have a problem with rendering in Sony Vegas 13 Pro for the android.
    I’m taking the vertically videos via my phone without changing any video and audio options.
    On PC BEFORE and after rendering it looks like this: https://i.ibb.co/6DnfbJ3/Clipboard01.jpg
    After I upload it to any of my android phones it looks like this: https://i.ibb.co/QbLdmRw/Clipboard02.jpg
    I tried to change the codec, frame and bit rate and frame size but nothing helped.
    My Android keep showing me this small videos regarding of parameters i chose.
    Please advise what’s wrong as on PC everything looks good.
    Aivis Zons replied 2 years, 11 months ago 2 Members · 3 Replies
  • Aivis Zons
    September 11, 2023 at 1:00 am
    If the problem is basically just on your android – have you tried a different video player on there?
    Otherwise you need to provide more specifics:
    1) Exactly what rendering templates are you using? What format is your video in?
    2) Was this working before? Did you change anything in your process/devices?
    3) Android version?
    4) What codecs/formats have you tried so far?
    A lot of unknown variables here.
  • lai maidan
    September 11, 2023 at 10:42 pm
    any templates causes the same problem
    It seems like this has never worked before on Vegas 13 Pro. Early versions (i dont remember)
    I have multiple android versions, but problem is the same
    all files are mp4 format
  • Aivis Zons
    September 12, 2023 at 1:31 pm
    Is your resolution really matching everywhere? Because I have a suspicion that it’s not.
    Can’t tell what resolution is your source footage, but let’s assume it’s 1080×1920 (portrait). You need to set your project resolution and render template resolution to this same value. If it’s the same everywhere then you should output files that 1:1 match your project preview on all devices.
    I’ve attached some images:
    For project properties – click on the cog wheel above video preview.
    Render settings – customize your template and select custom frame size.
    Reference what the resolution of your source footage is and input that instead of 1080×1920 in my example. Of course it could be that or it could also be 2160×3840 or 1440×2560…
