Activity › Forums › Adobe After Effects › Problem with rendering .avi file
Posted by Peter Wong on June 15, 2008 at 2:10 amI was working with some DV footage in After Effects and I rendered it to a .avi file using the Render Queue with the settings to “NO compression”. However, when I try to play back to .avi video in Windows Media player and other video players, the video is extremely laggy. I tried it on other computers and it yield the same laggy result.
Any help would be appreciated. Thanks!
Eric Robinsan replied 16 years, 3 months ago 4 Members · 7 Replies -
Chris Wright
June 15, 2008 at 11:23 pmthe hard drive cannont transfer the video information fast enough.
It’s normal. uncompressed can be useless for playback on un-godlike systems. That’s why they invented raid cards and render farms. -
Peter Wong
June 16, 2008 at 4:53 amSorry, I’m kind of new to the field of video editing. What is render farm?
So would my best bet to compress the video with some specific codec in the Render Queue. However, I want the video to be played by as many machines as possible since some computers may not have codecs installed.
Any suggestions on the most optimal way to render videos?
Chris Wright
June 16, 2008 at 6:38 amBoth Mac and PC can play Quicktime 7 codecs. That would be a good choice for universal playback. Try h.264. It can keep excellent quality and small file sizes. If you set it right, you can hardly tell differences between uncompressed and h.264 except that you can play h.264 on old computers smoothly. They use h.264 for a lower quality blue ray too. Mpeg2 is highest blue ray at 40 kbps. Youtube is also converting all its video to h.264. It’s like mpeg4 on steroids but can have DV quality. or try quicktime DV. I don’t know what your original footage is, but streaming always means quality vs time downloading. Your call. fyi. if your burning dvd’s or blu ray, then go mpeg2 highest dvd 8 mbps/dvd or blue ray mpeg2 40kbps.
mpeg2 does not look good at low bitrates. Use h.264 is you’re going that route. To compare and decide and save time, render out 40 frames or so and decide before spending 4 hours encoding undesired outpout. Hope this tidbit helps. -
Chris Wright
June 16, 2008 at 8:08 amI forgot to add, if you want lossless codec encoding, then you can try quicktime’s jpeg 2000, 20% better than regular mjpeg.
Peter Wong
June 16, 2008 at 2:17 pmMy original footage is from DV tape.
I am looking to render the video in a format that most computers can play, even those that do not have any codecs installed.
Also, I might bring the rendered videos into an older computer that uses Premiere 6.5 for some more editing.
Any suggestions?
Danny Hays
June 26, 2008 at 3:36 amWindows media video looks good and will play on most computers, Even macs with media player for Mac istalled. Danny
Eric Robinsan
June 1, 2010 at 1:39 amI am having a similar issue and I have a 10,000 rpm velociraptor and also a WD black 7200. I get the same issue regardless if I use the WD as my scratch disc or not.
Also, this used to work just fine for me and now it is not. I am stumped.
