Problem with recueing to end of tape on HDX900
I have found that after you shut down the camera and turn it back on and go to recue the tape by hitting the return button on your lens, that the tape isn’t cued to end of tape but actually cues about one second prior to end of tape. I have turned off the pre-record function so the buffer is not on and pre-record time is set to “0” but the problem still exists.
Any suggestions would be greatly appreciated.
BG
