Activity Forums Apple Final Cut Pro Legacy problem with quality after rotating video clip
  • problem with quality after rotating video clip
    Posted by Fuabond on November 28, 2006 at 7:15 pm
    Hi everyone!! I am having a quality problem after I rotate a little bit the clip to center it, also when I scale it bigger or smaller. I have to render it after I do this, but I loose quality after rendering, I loose a lot, I can clearly notice it.
    PLEASE HELP.
    thanks
    Felipe
    Fuabond replied 19 years, 10 months ago 2 Members · 2 Replies
  • Kevin Monahan
    November 28, 2006 at 7:30 pm
    Have you done the following?
    1. Viewed it on your external pro video monitor (not the computer monitor)?
    2. Changed the RT pop up menu to Safe RT? Full Quality (not Dynamic)? Full Frame Rate (not Dynamic)?
    3. Is the Sequence > Render > Full quality checked in the Sequence menu?
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Fuabond
    November 28, 2006 at 10:02 pm
    Kevin, thanks for responding, I made all the settings, but I still have the same problem, I don’t know if it has something to do with the rendering preferences, I realy don’t know about that that much
