Activity Forums Adobe Premiere Pro Problem with Premiere and the missing export to FlashCuepoint XML…
  • Problem with Premiere and the missing export to FlashCuepoint XML…
    Posted by Gordon Bush on October 22, 2019 at 10:44 am
    Dear Community,
    i ran into the following problem and i am currently trying to find a workaround. Since version 7 i think it was possible to export FLV-Cuepoint-XMLs directly from Premiere. Due to discontinuation this isn’t possible anymore. Does anybody now how a similar result can be achieved? I am using an online tool which needs to read this format. I found the possibility to export markers, but these are exported as timecode mm:ss:ff and not the syntax used in the CuePoint-XML file (maybe these were ticks?) so eventually there is some possibility to convert this? Any help is much appreciated!
    Gordon Bush replied 6 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
