Activity Forums Adobe Premiere Pro problem with premier pro
  • problem with premier pro
    Posted by Ivano Darra on April 7, 2009 at 5:27 pm
    I’m having the following problem with Premier Pro CS3: basically in the project window it shows the clips as if no effect was applied to them. If I click on a clip in the timeline though, the effects are still there, they are just not showing. I have noticed that if I right-click on a clip, choose “reveal in project”, unlink the clip and then link it to media, then the clip shows in the project window with the effects. The only problem is that if I save the project and then reopen it I am back to the same problem. It seems also not to save the rendering any longer, any ideas on how to solve this??
    thanks
    Ivano Darra replied 17 years, 5 months ago 1 Member · 1 Reply
  • Ivano Darra
    April 8, 2009 at 11:15 pm
    thanks for the links posted, I’m checking them to see if this – or some similar case – is mentioned, although I haven’t had much luck so far. I would like to add that a previous version of the project – with quite substantial differences although containing basically the same clips – seems to work well. Maybe this only makes things more unintelligible?
