Activity Forums Adobe After Effects problem with pre-compose
  • problem with pre-compose
    Posted by Gary Jarvis on December 4, 2011 at 4:01 am
    I am doing an animation, in my animation I have 68 characters, I’m making a mouth movement by just going from wide to small and narrow over 40 frames. I have been using the same movement for them all by (apple D) duplicating and repositioning, a bunch of them have a turquoise # type of logo in the layer name.
    My situation is that, when I try to pre-comp all the layers I lose the lips. Can anyone help
    Tks
    Gary
    Angie Taylor replied 14 years, 6 months ago 2 Members · 4 Replies
  • Angie Taylor
    December 4, 2011 at 9:06 am
    Hi there,
    Are the layers 3D? If so then try clicking on the Collapse Transformations switch. You may also need to make the precomp a 3D layer.
    Hope this helps!
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
  • Gary Jarvis
    December 4, 2011 at 11:05 am
    G’morning Angie,
    No, actually I haven’t got to the 3d stage yet, still working on the basics, but thanks anyway.
    By the way, do like your dancing bottles and the puppet tool, as a matter of fact, after seeing that vid I was able to come up (I think I was original anyway) with a way of using the puppet tool to lip sync all my characters.
    Tks Gary
  • Gary Jarvis
    December 4, 2011 at 11:45 am
    The problem is in the blue # type shown in the beginning of each of the title to some of the layers, hmmm he thinks, is there a different process used in the different layers.
    I took the layers w/o the blue # type sign and pre-comped them, perfect, no problemo
    Now it’s time to pre-comp the layers w the blue # sign, hmm everything disappeared.
    What’s the difference in the actual process?
    Well, the layers w/o blue were initially duped, and then within each layer, were transformed to a new position and key-framed by actually entering a digi # into the horizontal and vertical location in transform/position.
    As opposed to the layers w the blue # sign which were, dragged and key-framed into position,
    Well including the re-do’s I have another 54 dupes to go so, dragging as a process was much faster.
    Have a g’day
  • Angie Taylor
    December 4, 2011 at 12:31 pm
    Hi Gary,
    Glad u liked my dancing bottles! 🙂
    Have you tried toggling the Collapse Transform switch to see if that helps?
    If you want to upload your project I’d be happy to take a look.
    Cheers,
    Angie
    cheers,
    Angie
