Activity › Forums › Sony Cameras › Problem with Pixilation with the NEX-FS100U Camera
  • Problem with Pixilation with the NEX-FS100U Camera
    Posted by Thomas Hughes on July 12, 2011 at 8:28 pm
    I have a question about the NEX-FS100U. If this is the wrong forum, please suggest the correct one. Tx
    We bought it with the 120GB back, the HXR-FMU128, which uses USB as it’s connector when loading to edit. We took delivery Thursday, did tests Thursday & Friday then shot with it Saturday. We shot 1080/60i, bit rate: FX – 24mb/sec. We loaded it to FC using Clipwrap pro-rez 422 and watched it. We also loaded it as QT files to the Mac and watched it that way too. When watched on the camera’s monitor, the footage is perfect. When watched on the edit suite, whenever there’s movement, it has unacceptable levels of pixilation.
    We’ve tried several different ways of loading it to the suite and we always end up with the pixilation.
    How do we get rid of the pixilation? Did we shoot on the wrong setting or are we diging the footage incorrectly? Thanks for any input.
    Thomas H
    Uli Plank replied 15 years, 2 months ago 5 Members · 4 Replies
  • David Eaks
    July 12, 2011 at 10:50 pm
    Recording in 1080i60 in FX should look great, since playback looks perfect on-camera there must be a problem with your method of transfer to FCP.
    I cant speak to the NEX-FS100U OR HXR-FMU128 specifically but with my NX5U’s (w/ SDHC Cards), I do the following.
    Copy the entire recorded media to the computer (be sure to keep the original folder structure in-tact, no fussing with individual files/folders).
    Open it (the “private” folder) in FCP’s “log and Transfer” window. Set the name, clip counter etc.. Begin transfer.
    Edit the beautiful resulting Prores clips.
  • Douglas Villalba
    July 14, 2011 at 12:25 am
    Are you viewing it on an external monitor or the computer’s? I’ve heard stories of people viewing the footage on computer monitors with resolution lower than 1080 that showed strange pixelation, but when the same footage was viewed on a high resolution monitor it looked great. Another reason could be interlaced footage on LCDs, LEDs or Plasmas.
    Douglas Villalba
    https://www.advertising-villa.com
    info@dvtvproductions.com
    Chroma-Key – Studio, Decklink HD Extreme, HVX200, A1 & HV20. VDSLR, GlideTrack, Rails, GlideCam, Jib
  • Michael Johnston
    July 15, 2011 at 5:28 am
    You can do a search on Amy forum and you’ll see a lot of people have been having issues using NXCAM AVCHD footage in FCP. However, I can say that my footage from my NX5U dies not look great on my laptop in Premiere either but is amazing once its exported and viewed in Windows Media Player. I think it really is just viewing an interlaced video on a progressive scan laptop display. I hope you figure it out. I try to stay away from AVID & FCP because of their lack of willingness to allow all formats to be used natively in those programs. No reason MPEG2 & AVCHD can not be used natively in those programs.
  • Uli Plank
    July 19, 2011 at 9:37 am
    I get excellent results in Premiere Pro Cs 5.5 on a beefy machine (8-core, 24 GB RAM).
    Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
