Activity › Forums › Adobe After Effects › Problem with Pasting Mocha Shape Data
  • Problem with Pasting Mocha Shape Data
    Posted by Romeo Meier on September 16, 2012 at 9:06 am
    I hope I’m at the right place here I’m not sure if my problem is Mocha or After effects however i couldn’t find a Mocha forum anyway so i decided to post it here.
    I want to past Mocha shape data in after effects i tried with cs4 and cs5.5 by both this error message comes up (see link please)
    https://www.flickr.com/photos/49583182@N00/7991156097/
    (the only diffrent is in cs4 it says line 10 and in cs5.5 it says line 16)
    …and yeah it used to work when i did it last time but that was 6 month ago
    what do i wrong? or where is the mistake i need to be abele to correct this!
    Roland R. kahlenberg replied 14 years ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    September 16, 2012 at 10:08 pm
    Check that you have the mocha Shape plugin installed. You should take a look-see under Effects>Matte. Let us know.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Romeo Meier
    September 19, 2012 at 6:12 pm
    yeah that was the problem i got the plugin in the meanwhile.
    But now there is still one more thing:
    i need an activation code for the plugin LicenseManager where do i find that code?
    and does it cost anything?
    cause i got mocha for AE why do i have to do these things, why isn’t it shiped already or built in or better why does after effect has not included the plugin since mocha comes with AE?
    THANKS SO FAR!
    Romeo
    September 20, 2012 at 1:21 am
    The earlier versions of AE had mocha on a separate installer disc. You’ll want to check your discs to find the installer. If you’re still having issues then write to Imagineer directly – https://www.imagineersystems.com/contact_form
    HTH
    RoRK
