Problem with P2 Iin FCP 6.0.4 Preview Window Using HVX 200
PROBLEM WITH P2 IN FCP 6.0.4 PREVIEW WINDOW Using HVX 200
I recently started experiencing an unexplainable phenomenon while trying to use the Log & Transfer PREVIEW window. On my most recent shoot I wanted to spot check some shots I had just copied to my external hard drive (G-Raid) using a Duel Adapter and Mac Book Pro. Usually I just use the FINDER and drag and drop the CONTENTS and TXT folders directly to my external hard drive (at the same time)
(Within Final Cut Pro 6) The Log & Transfer window’s PREVIEW window was gray and it showed text that read ” Preview not supported for this format”
I could not get any of the files to play in the PREVIEW window. The only way I could view them was to drag them into the ingest queue and bring them into FCP. There I could see them and they played fine.
Every attempt I have made to troubleshoot this problem has led to a dead end:
1.) Suspecting it was a FCP issue I tried copying the media directly from my HVX200 camera and then looking at it in Log & Transfer. When I did this it worked fine. No problem seeing it in the PREVIEW window and playing it. (therefore probably not a FCP issue)
2,) I then suspected the Duel Adapter. I called Duel Adapter’s tech department and they said they have never had a call like mine before. They said the Duel Adapter was probably not causing the problem because it either works or it doesn’t. It could not create a secondary problem like mine.
(side-note) I did try to view the media directly off the P2 card in FCP’s Log & transfer PREVIEW and I was able to see the media however it was inconsistent. Sometimes it would show the media and play fine and on other clips it was grayed out and would not play.My most recent tests however ALL the clips played fine and were viewable using this Duel Adapter test.3.) I also tried copying directly to my Mac Book Pro hard drive but using the Duel Adapter I continued to have the same gray window in PREVIEW but only when using the Panasonic P2CMS interface. When I used the FINDER and just dragged and dropped them into a Text folder on my desktop I could see the files just fine in the PREVIEW window. HOWEVER I should point out that this is intermittent…sometimes it works and sometimes even using the FINDER and copying directly to the Mac Book Pro HD I sometimes still get the GRAY PREVIEW window in FCP.
I had been told by a Panasonic Tech that you MUST use the P2CMS to transfer files. Do NOT use the FINDER as this can cause all kinds of problems. However that has never been the case before I had this problem and it doesn’t seem to be helping solve this problem either.I have not yet tried going through this process using the Duel Adapter on another Mac Book Pro. I will be testing on my friend’s Mac Book Pro soon and see if I get the same results. However at this point I don’t have any idea why it is doing this. I have never had this problem in the past. My process of dragging and dropping P2 media using the FINDER and the Duel Adapter has always worked flawlessly.
If ANYONE out there can help me find an answer please write me!
Thanks you, Jim Coulter
Moving image Productions
jim@movingimageinc.com
