Activity › Forums › DaVinci Resolve › problem with opening Audio file in resolve 9.1
Posted by Hamid Ghodrati on February 13, 2013 at 7:28 amhello everyone
I cant open audio file in my resolve9.1 lite, i cant even see audio file in my library ( i tried different audio format ) !
Any guess ???Thanks for the help.
Hamid Ghodrati replied 13 years, 7 months ago 3 Members · 8 Replies -
Al Arnold
February 13, 2013 at 4:59 pmAre you trying to open a wave file? I haven’t been able to open an AIFF in either Linux or Mac…
Hamid Ghodrati
February 14, 2013 at 10:11 amyes arnold wav and other audio format
davinci cant see none of them o-( -
Al Arnold
February 14, 2013 at 5:27 pmIs it a Broadcast or regular wave? Does it open in other software? What about creating a QT with the audio and extracting it in Resolve? Can you see the Wave file created that way?
Hamid Ghodrati
February 15, 2013 at 12:33 pmregular wave.
and about creating Qt i don’t know how to do that ???
( if you don’t mean quick time ) -
Al Arnold
February 15, 2013 at 5:55 pmYes, quicktime. You can extract audio from a quicktime for use in resolve. Just wondering if you can see the audio created directly from Resolve. Also, what OS/Hardware are you running? Have you tried playing the wave file in different software yet?
Hamid Ghodrati
February 16, 2013 at 9:51 amyes Arnold,
now by extracting audio by qt i can see and play and work by wave file, my os is windows7 .
is this the only way (extracting by qt) to see audio file in resolve ?
or there are other ways ?thanks in advances ‘
Rohit Gupta
February 16, 2013 at 11:01 amPlease check the properties of the wave file you have vs the one extracted from Quicktime?
You need to have uncompressed 48 Khz wave file, 16/24/32 bit.
Hamid Ghodrati
February 17, 2013 at 7:18 ammy previous wave had 44100hz,16bit
and qt extracted has 48000hz,32bit
so the formula is : uncompressed 48 Khz wave file, 16/24/32 bit ?
