Activity › Forums › VEGAS Pro › Problem with open .veg files in different Vegas Pro 9.0 programs
  • Mike Kujbida
    October 13, 2013 at 3:38 am
    I can do that. Theo, see if this works for you.
    6630_theonew.veg.zip
  • Theo Dorus
    October 15, 2013 at 12:21 pm
    Thanks for your investigations, Stephen and Mike,
    Mike, I tried to open your (zip) file, (also on a new location) but i still get the same message.
    At the moment i’m very occupied, later this week(end) i continue.
    I will post a message about the results.
    kindly regards, theo
  • Francois Blawat
    March 27, 2014 at 5:56 pm
    Hello,
    I know this post is old, but I am wondering if you tried this with the .veg file. This is assuming you copied the .VEG file and all related files to a local hard drive.
    Since this file came from another system, I am wondering if you have to “unblock” the file before it will open correctly for you?.
    I have attached a graphic showing where you would Unblock the file:
    The other option is if you have older Sonic Foundry programs on your system, you may need to run the Sony Utility to make sure all the correct plug-ins get associated to the Sony Vegas Program.
    I have Vegas Pro 9.0e where I am at, and the file also opened up correctly for me as well.(just missing the media files)
    Hopefully one of these work for you.
    FixitMAD
Page 2 of 2
