Activity Forums Adobe After Effects Problem with nulls from 3D camera track
  • Problem with nulls from 3D camera track
    Posted by Adam Lewen on March 31, 2014 at 8:28 pm
    Hi!
    I am having problems and i’m trying to find a solution
    https://youtu.be/jxZmd7p34LI
    I have an animation of a map fly over
    I solved a 3D camera track and it helped in adding a path along the map – Great
    I am also trying to add signs (those colored plates)
    Problem is – I can’t figure a way to have them parented to the map or nulls without getting skewed
    The skewing is due to the camera to begin with…
    I’m trying to figure a clean way of having these color blocks straight and nice – without doing it manually
    A “regular” tracker does not seem to help me either.
    I hope I make sense with my question
    I have been trying to tackle this for a while :-\
    Example above
    Adam-
    Adam Lewen replied 12 years, 5 months ago 2 Members · 2 Replies
  • Walter Soyka
    April 1, 2014 at 3:49 am
    You will probably benefit from Dan Ebberts’s expression to orient a layer to the camera plane. Alt-click the stopwatch for a layer’s orientation property and paste in the following:
    L = thisComp.layer("Camera 1");
    u = fromWorldVec(L.toWorldVec([1,0,0]));
    v = fromWorldVec(L.toWorldVec([0,1,0]));
    w = normalize(fromWorldVec(L.toWorldVec([0,0,1])));
    sinb = clamp(w[0],-1,1);
    b = Math.asin(sinb);
    cosb = Math.cos(b);
    if (Math.abs(cosb) > .0005){
    c = -Math.atan2(v[0],u[0]);
    a = -Math.atan2(w[1],w[2]);
    }else{
    a = (sinb < 0 ? -1 : 1)*Math.atan2(u[1],v[1]);
    c = 0;
    [radiansToDegrees(a),radiansToDegrees(b),radiansToDegrees(c)]
    Walter Soyka
  • Adam Lewen
    April 1, 2014 at 7:00 am
    Thanks Walter
    Unfortunately the script gave me a similar result to what I had. But I did manage to fine a solution that I was happy with.
    Analyzing again and changing the 3D track camera to a fixed and specifying my own angle of view (a really wide one worked great :-0 not sure why, I will test to see more results)
    But this way I managed to have the colored planes moving with me in a nice manner!
    Thanks for replying and I will save this script for future tasks!
    Adam
