problem with motion tracker, boris fx trialversion in vegas pro
James Dekle replied 11 years, 10 months ago 4 Members · 13 Replies
James Dekle
November 11, 2014 at 1:58 pmHi John,
Thanks for getting back with your help,it’s much appreciated.
I don’t believe I am using Dynamic Ram Preview as the the Max (MB) setting in video is zero. According to the help info on 13, that turns off Dynamic Ram Preview. Was that what you were referring to?
Any suggestions, got to be something dumb I’m doing, clip is short and not very complicated.
Best regards,
Stuckshutter -
John Rofrano
November 11, 2014 at 2:51 pm[James Dekle] “I don’t believe I am using Dynamic Ram Preview as the the Max (MB) setting in video is zero. According to the help info on 13, that turns off Dynamic Ram Preview. Was that what you were referring to?”
Yes, and that’s your problem! You MUST use RAM Preview in order to Motion Track. So give RAM Preview a few GB of memory and then to start tracking use Shift+B to start the RAM Preview. This will force Vegas Pro to display every frame and the motion tracker will be able to follow it.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
James Dekle
November 11, 2014 at 3:44 pmThank you John,
I knew it was something I was not getting. I’ve got it tracking now.
Still guess I need a tutorial on using the multiple settings on the wire remover since it’s tracking but the wire isn’t getting removed.
Any suggestions where I can get a good tutorial on all the tracking CF, end 1 end 2 etc? settings and what they do?
I’ll get it and it will be handy, but it’ll take a bit more explanation since I’m not getting it just yet.
Anyway, thank you for your help, it’s always great and very much appreciated.
Best regards,
Stuckshutter
