Activity › Forums › Adobe After Effects › Problem with Motion Blur
  • Problem with Motion Blur
    Posted by Can Köprülü on November 28, 2009 at 11:29 am
    Hello folks,
    I have a problem with After Effects CS4. When I render my animation with Motion Blur activated, the Blur kind of “hangs” after the last frame in motion. Let me explain: The moving text already stopped, but the blur is still there, looking exactly the same like in the last frame the text moved. This only happens, when I render. In the preview everything is perfect. I already tried to split the layer at the frame after the text stopped moving and deactivated motion blur for this layer. With no result, still the same result after rendering.
    Does anyone know this problem? Did’nt find anything using google…
    Can
    Jeremy Cox replied 16 years, 9 months ago 2 Members · 2 Replies
  • Can Köprülü
    November 30, 2009 at 3:15 pm
    OpengGL already was turned off and the Footage are Adobe Illustrator Files.
    I now rednered the Clip two times. One time with Motion Blur on and one time with Motion Blur turned off, afterwards I put the two Clips together at the Critical Point, no good workaround!
  • Jeremy Cox
    December 6, 2009 at 11:02 pm
    Make sure your Shutter Phase is set to 0 and that none of your keyframes are between frames (can happen if you are stretching or time remapping). After effects thinks the motion is starting/stopping part way through the frame. Imagine if you took a photo with the shutter speed set to 1 second, but the camera was moving for the first 1/2 second and was perfectly still for the second 1/2 second.
