Activity › Forums › Adobe After Effects › Problem with more space of work
  • John Cuevas
    October 4, 2012 at 7:58 pm
    Are you asking how to create a composition longer than 4 seconds? If that’s, select your composition and press “Cntl + K” and at the bottom of the comp dialogue you set the duration time of the composition.
    Also for us to see your image, you have to select the image from the right and copy the embed code from the left.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
