Activity › Forums › Maxon Cinema 4D › Problem with modifying a converted object
  • Problem with modifying a converted object
    Posted by Diane Koro on August 29, 2010 at 12:30 pm
    Whenever I try to create a shape by modifying a C4D object (making editable) it doesn’t come out right. For instance, see the image attached…I want the shape on the right which has nice sharp edges (used a boolean of pyramid and cube objects). The one on the left, I made a cube editable, then selected the top polygon, sized it and moved it down. Why doesn’t it look like the one on the right? What am I doing wrong here?
    Diane Koro replied 16 years, 1 month ago 2 Members · 2 Replies
  • Brian Jones
    August 29, 2010 at 3:41 pm
    You are looking at the effect of the Phong tag. Without it you see every polygon even if you want a smooth surface. In this case the it’s smoothing too much, just reduce the Phong Angle in the Phong tag.
  • Diane Koro
    August 29, 2010 at 3:55 pm
    Excellent, thank you!
