Activity Forums Blackmagic Design Problem with mixed timeline in Premiere Pro
  • Jeff Kosmicki
    March 6, 2007 at 8:47 pm
    Another quick workaround is to move the DV clip with that needs rendering up or down one pixel, this will also reverse the dominance.
    Jeff Kosmicki
    http://www.toyraygun.net
  • Shane Chadder
    March 7, 2007 at 1:03 am
    I select one DV clip on the timeline, shift it up a line in the motion settings and copy the attributes to all the dv clips on the timeline.
    I don’t know why they can’t build this in.
  • Guillaume Choquette
    March 8, 2007 at 7:46 pm
    Yes, I’m lucky I remembered that trick the day before I had to output the video. It’s still problematic with DV clip that are only partially rendered. The workaround to the workaround is to add any effect so the whole clip will render.
    But when you need a workaround to a workaround, there’s definitely something wrong…
