Activity Forums Adobe Premiere Pro Problem with Mac AVi on Premiere PC
  • Problem with Mac AVi on Premiere PC
    Posted by Accountneedsrealnameupdate on October 25, 2007 at 12:29 am
    Hello
    I’m having an issue with an AVI file I’m sending to a client who uses Premier on a PC.
    I generated a QT file from FCP, and converted it to AVI using QuickTime, and as compressor used the DV-NTSC codec.
    This did not work on his system, it would not open.
    I then made a sample in AVI Uncompressed, which worked, but the file is 4 times bigger. This is a problem since we need to FTP files to each other.
    Does anybody know of a workaround for this?
    Thanks in advance
    Alex
    Mike Velte replied 18 years, 10 months ago 3 Members · 4 Replies
  • Mike Velte
    October 25, 2007 at 11:43 am
    Microsoft’s DV.avi comes in 2 flavors; DirectShow type 1 and 2. Premiere can only open type 2.
  • Tim Kolb
    October 25, 2007 at 2:39 pm
    In my experience, the QuickTime DV files are far better cross-platform files than AVI if you both have CS3 and the PC has QT installed of course.
    TimK,
    Director, Consultant
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Accountneedsrealnameupdate
    October 25, 2007 at 3:59 pm
    Thanks for the replies.
    Unfortunately my client seems to have problems with QuickTime files..
    The only format that has worked so far is AVI uncompressed. But the filesize is too big.
    How would I create a compatible DV-NTSC file?
    Alex
  • Mike Velte
    October 26, 2007 at 10:37 am
    You might also ask this question on the FCP forum. You can create a DV-NTSC DV.avi just fine, but not the type 2 that Premiere can ingest.
