Activity Forums Adobe Premiere Pro Problem with loudness normalization on export.
  • Problem with loudness normalization on export.
    Posted by Chris Paul on December 30, 2015 at 4:12 pm
    I was initially happy to see that Adobe had added loudness normalization to the export setting in Premiere Pro and Media Encoder. Unfortunately I have found that if the audio starts in silence (as is required by some TV stations) the use of this setting results in a brief burst of noise followed by silence for the rest of the program.
    Chris Paul
    POV
    Tero Ahlfors replied 10 years, 4 months ago 2 Members · 1 Reply
  • Tero Ahlfors
    December 30, 2015 at 5:01 pm
    That’s a problem because those tails and heads shouldn’t be counted in the loudness normalization. You can easily do loudness normalization in Audition’s match volume panel.
