Problem with LHe capture since FCP upgrade
Hi all
Recently upgraded from FCP 6 to FCP 7 (or 09 or whatever it is called). My LHe card has continued to happily send video to my monitor via component. However now I come to capture my usual way (PAL DigiBeta from a Sony J30 using 9 pin remote and Kona’s SDI to Pro Res) I get only green shash or interference in the log and capture window. If I switch to component out of Kona then I get only solid purple. I can successfully get DV through the deck’s firewire, so it is not a problem with the tape.On the upgrade I was running driver 6.02 but have since uninstalled this and run 6.5 and now am on 7.0 – all give the same result.
I am stumped. Could it be a hardware fault? I know AJA products are very reliable and a driver issue is the most likely cause, but I feel like I have tried every configuration. AJA conflict checker has come up with nothing also.
MacPro late 08 dual quad intel xeon 2.8Ghz 8 GB RAM running Leopard 10.5.8 and FCP 7.0
I would be very grateful for any suggestions or wisdom
