Activity Forums Adobe After Effects Problem with keyframes
  • Problem with keyframes
    Posted by David Yowell on December 2, 2009 at 6:19 am
    I am a relative rookie to AE, but I have been successful with quite a few projects. However, I am having a problem with setting keyframes. I have project that is 640×480. I have a JPEG of a brick wall that is about 1000×800 and it has some pictures that look as if they are hanging on the brick wall with nails in them. I want to show each of these pics so I began the project by setting a keyframe at frame 1. I zoomed in on the pic in the far right-hand corner. I then moved the CTI to about 5 seconds and zoomed out of the pic. However, when I zoom out, the edge of the bricks could be seen and I didn’t want that. So I panned a little to the left set those keyframes. Here’s where my problem lies. When it zooms out of the first picture, you can still see the edge of the bricks and then it moves over. My question is, what am I doing wrong. I want it to zoom out and still just see the bricks, not any of the background.
    I know that I’m doing something really stupid here, but I just can’t figure it out. I would appreciate any help that you can give me.
    David Yowell replied 16 years, 9 months ago 59,925 Members · 1 Reply
  • David Yowell
    December 3, 2009 at 3:38 am
    Thanks for your response Dave. I tried what you said, but didn’t have any luck. I’m probably not explaining myself very well. Here’s what’s happening.
    I have a JPEG brick wall that’s a little bigger than the project that I’m working on. On the Brick wall are 11 pics that look like they are tacked onto the wall with drop shadows behind them. All of this is one JPEG that I did in Photoshop. I begin the project with a closeup of one of the pics an slowly scale back so that the pic is still the only thing on the screen, just not as much as a closeup as the beginning. This runs for about five second. Then in 15 frames, I move to another pic on the wall and scale it so that it’s the only thing in the picture. I do the same thing with this pic in that I slowly scale it for about five seconds and then quickly go to another pic within 15 seconds. I want to do this for all of the pics.
    So Dave, here’s my problem. When I’m working on the pics in the corners, after I set the keyframes, as I scale out, it keeps showing a little bit of the black, outside of the brick wall. I can’t figure out why. I know this is confusing, but if you have any ideas, I would really appreciate your help. Thanks again.
