John Rofrano
January 27, 2013 at 3:34 pm[Michal Bronec] “Yes, thats exactly what I am looking for. But my Vegas bahaves like this:”
That is behaving like Iris Out. What does Iris Out look like? Try switching it back and forth.
[Michal Bronec] “As you can see the second problem is that its not a circle! :)”
I can also see that your project is 1440×1080 which begs the question, what are your full project properties and media properties.
[Michal Bronec] “Maybe a bug in Sony Vegas 11?”
Not here with Vegas Pro 11.0 Build 701. Are you using the latest build?
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Michal Bronec
January 27, 2013 at 5:11 pmIris out looks same – the only difference is that the black circle gets smaller, not bigger.
The shape originaly was a circle, but when I switched it to an oval shape ant then back to the circle, the oval shape remained (even on other events).
I have build 370.
John Rofrano
January 27, 2013 at 5:48 pm[Michal Bronec] “I have build 370.”
Well you’re only 371 builds behind build 701. 😉 I would recommend that you install the latest version and your problems with most likely go away.
~jr
Roger Bansemer
January 27, 2013 at 6:10 pmDidn’t realize you posted before me. I misunderstood the question as well.
John Rofrano
January 28, 2013 at 11:16 am[Michal Bronec] “Same problem in 700 build. I have the 32-bit version.”
I’m using build 701 and I don’t see the problem. 700 and 701 should be the same except for one being 32-bit and the other 64-bit but only Sony knows for sure. Make sure that you are trying it on a new project and not inheriting the bug from the old project.
~jr
