Activity Forums Apple Final Cut Pro Legacy Problem with I/O
  • Problem with I/O
    Posted by Spotcharlie on February 9, 2007 at 2:35 pm
    I just upgraded my FCP to 5.1 I have an AJA Kona Lh for some reason i can’t get playback on my external monitor. If i select current frame from playback options i can see the still, but when i switch back to all frames nothing happens. No settings were changed to my av devices between the last time i used it as 5.0 and this time as 5.1. Any help is much appreciated thanks.
    Walter Biscardi replied 19 years, 7 months ago 2 Members · 1 Reply
  • Walter Biscardi
    February 9, 2007 at 2:42 pm
    If you did the CrossGrade, you should Uninstall your Kona drivers and reinstall them. Go into applications > aja kona utilities. There is an Uninstaller there.
    Then download the latest drivers from the AJA website and re-install.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
