Activity Forums Adobe After Effects Expressions Problem with interpolation expressions controlling position/rotation
  • Problem with interpolation expressions controlling position/rotation
    Posted by Guilherme Oliveira on December 13, 2012 at 7:41 pm
    Hello folks,
    I’m really bad at coding but somehow I managed to put together some eyebrown animation based on audio amplitude + position/rotation interpolation expressions but it came out very choppy 🙁
    The thing is: I got the eyebrowns (which are represented by a red shape at the moment) of my character to move when the audio amplitude peaks but I need the movement to be smoother
    Here’s a piece of the animation so you can see what I’m talking about:
    https://www.youtube.com/watch?v=1LtmCGmWWvs
    Let me know if you need any more details and thanks in advance
    Edit: My goal here is to animate the eyebrowns only when the audio peaks to give some surprise/enthusiasm look on the face and to accomplish that I’m using the highest values of the audio peak as trigger but if you guys have a better idea I’m all ears 🙂
    And heres the expressions:
    Position:
    volAmp = thisComp.layer("cabeca inteira boca fechada").effect("Voice Volume")("Slider");
    ease(volAmp, 80, 90, [706,260], [706,250]);
    Rotation:
    ease(volAmp, 70, 90, 0, 5);
    Guilherme Oliveira replied 13 years, 8 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 13, 2012 at 9:51 pm
    My guess is that what you really want is an animation that is triggered by the audio level going above a certain value. That’s a more complicated application. Hopefully this will explain the issues and how you detect the peaks:
    https://www.motionscript.com/design-guide/audio-trigger.html
    You’ll probably want a different animation than the oscillation example, but if you get that far come back and ask more questions.
    Dan
  • Guilherme Oliveira
    December 13, 2012 at 10:18 pm
    That’s a approach that I haven’t considered! I’ll give it a try, thanks!
