Activity › Forums › Adobe Premiere Pro › Problem with interlacing
Posted by Tom Kennedy on December 17, 2012 at 4:11 amI’m having trouble de interlacing clips.
When I view them in premiere they look fine, but when I export them they look interlaced.
The original clip does not appear to be interlaced when I play it back, but somewhere in the export process it gets interlacing.
I have tried changing the field order, checking always de interlace and tweaked the export settings but am having no luck.
Any help would be greatly appreciated.
Jeff Pulera replied 13 years, 8 months ago 4 Members · 6 Replies -
Jeff Pulera
December 17, 2012 at 4:09 pmHi Tom,
We’re going to need some details before anyone can help. Please share the following –
Format of SOURCE video, incl. frame rate, for instance “AVCHD 1080i 29.97”
Editing Sequence settings used in Premiere
Export settings in AME
If you can post screen grabs of any of this, very helpful
Jeff Pulera
Safe Harbor Computers -
Tom Kennedy
December 17, 2012 at 10:43 pmThanks Jeff,
I’m using four different types of clips in my project, two archival footage and two different interviews shot by two different people.The first archival footage clip is mpg 25fps 720×576
The second archival footage clip is .mov 25fps 720×576
The first interview footage clip is .mov 25fps 1024×576
The second interview footage clip is .wmv 25fps 1024×576The editing sequence settings are DV Pal, 25fps, 720×576
Export settings are H.264, pal, 1280×720, 25fps, upper field first
Here is a screen shot of the sequence settings
Here is a screen shot of the export
I hope this is helpful, I’m thinking it must be something to do with the order of the fields but I can’t figure it out having tested multiple export settings.
Cheers
Jeff Pulera
December 17, 2012 at 11:22 pm720p is always progressive, not sure why it would even give you an option for upper or lower field. Any time you are encoding for the web or computer viewing, you ALWAYS want Progressive, since computer displays are not interlaced.
Change FIELDS to NONE, that should do it!
Jeff Pulera
Tero Ahlfors
December 18, 2012 at 4:57 amYour sequence settings are DV PAL which is lower field first and you’re trying to export it with upper field first. Why is that?
Carole Jones
December 18, 2012 at 7:39 pmHi Jeff,
you have previously helped me a great deal, tried to find you and did….:-)
could you please tell me how to drag multiple clips from a sequence back to a bin, as otherwise I have a big chaos….I originally did it to add audio to video, it took me days….
hope you dont ask me to do a workaround as i really am used to do it that way from the bin to the timeline…
thxs a lot…..if you cant helpt, thanx anyway;-) -
Jeff Pulera
December 18, 2012 at 8:19 pmHi Tom,
Curious – your source clips are all SD, but you are exporting to HD. What is the destination for these vids? You may be losing some quality by upscaling if you don’t need to. The 1024×576 setting is the square-pixel version of SD widescreen, as matches two of your source clips.
Jeff Pulera
