Activity › Forums › DaVinci Resolve › problem with importing a project from resolve(linux) 8.0.1 to mac 8.0.1(mac)
Posted by Prathvish Hegde on August 3, 2011 at 1:15 pmhi all,
i have been trying to import a project from my linux system to my mac system but nor-thing seems to be happening .
i had done this earlier with version 7 and all seemed to be fine.is anyone facing the same problem?
prathvish hegde
coloristPrathvish Hegde replied 15 years, 1 month ago 3 Members · 7 Replies -
Peter Chamberlain
August 3, 2011 at 2:06 pmHi, assuming you do have the exact same version, you can try to isolate your problem a little with a few tests as this should work. Try importing the project back into the Linux and verify the import. On the Mac, export a project and check that imports back into the mac. Test the mac to the Linux. If these tests don’t help guide you to a successful result contact davincihelp@Blackmagic-design.com with your project and the support guys can check for you.
Peter -
Prathvish Hegde
August 3, 2011 at 5:08 pmhi peter,
thanks for the response.
export from resolve(linux) and import back to resolve seems to be fine.but the export from resolve linux and import into mac resolve dosent work.prathvish hegde
colorist -
Prathvish Hegde
August 3, 2011 at 5:13 pmhi,
after 4hours of trial and after the client leaves irritated.
tried again changed nor-thing but the same project loads.
all fine except the client.🙂
prathvish hegde
colorist -
Christopher Tay
August 4, 2011 at 1:37 amWhat error message did you get when you try to import the Resolve Linux 8.0.1 project into Resolve Mac 8.0.1 ?
-chrispy
Prathvish Hegde
August 4, 2011 at 7:47 amno error at all just the default session shakes and northing seems to be happening.
prathvish hegde
colorist -
Prathvish Hegde
August 4, 2011 at 7:50 ami thought it was sayin to me i hate linux projects just by shaking it head(projects on the project tab)
will try today and see and get back
prathvish hegde
colorist -
Prathvish Hegde
August 4, 2011 at 3:39 pmall seems to be fine tried importing and exporting to and from linux to mac.
i think it was a bad dayprathvish hegde
colorist
