Activity › Forums › Adobe Premiere Pro › Problem with imported Cineform files
  • Problem with imported Cineform files
    Posted by Brian Peterson on May 15, 2012 at 4:34 pm
    Hello,
    I’ve run into a problem, and am wondering if anyone else has seen the same issue. I’m editing Canon DSLR footage that’s been converted to AVI using Cineform Neoscene.
    The files all seem fine…but when I import them into Premiere Pro (5.5) or After Effects, they’re dramatically truncated. They play back just fine, but a file that’s, say, 9:15 in length comes into Premiere as 2:47. I’ve tried re-converting the clips, but I get the same result. Oddly enough, they open perfectly (and at at the proper length) in Vegas Pro.
    I’d certainly appreciate any ideas/help anyone can offer!
    Brian
    Brian Peterson replied 14 years, 4 months ago 2 Members · 2 Replies
  • Jake Segraves
    May 15, 2012 at 7:23 pm
    If your CineForm files are being truncated in Premiere, that means that Premiere is not using the CineForm file importer. Re-installing Neoscene will add the file importer into CS3 through CS5.5. Try that and then relaunch Premiere and/or AE and you should then see the compete file.
    Jake Segraves
    Technical Support Manager
    CineForm | GoPro…Be a HERO.
  • Brian Peterson
    May 16, 2012 at 2:31 pm
    Thanks, Jake…I’ll give that a try and see what happens.
