Activity Forums Apple Final Cut Pro Legacy Problem with image sequence with more than 99999 tiffs
  • Problem with image sequence with more than 99999 tiffs
    Posted by Andrea Marini on September 30, 2011 at 6:57 pm
    We exported a tiff sequence for a DCP master, but after 99999 files FCP started again from 00001 overwriting the first part of the movie. The project is 74 minutes long.
    Is there a workaround for that?
    Rafael Amador replied 14 years, 11 months ago 4 Members · 6 Replies
  • Andrea Marini
    September 30, 2011 at 8:05 pm
    Errata corrige: the tiffs stopped at 65536. I found a similar post here on the cow but without a solution other than bringing the movie to a post house https://forums.creativecow.net/thread/8/1114564
  • Michael Gissing
    September 30, 2011 at 10:47 pm
    Split the project into 20 minute reels.
  • Christian Schumacher
    October 1, 2011 at 3:54 am
    Have you tried to export a MOV to open it in QT 7 and do it from there?
    You could try it in Compressor and After Effects too.
  • Rafael Amador
    October 1, 2011 at 7:01 pm
    [Christian Schumacher] “Have you tried to export a MOV to open it in QT 7 and do it from there?”
    If I can remember, that limit the number of stills you can manage as a sequence, or for exporting a movie.
    I guess is a kind of QT limitation; something like the limited length of movies.
    Rafael
    http://www.nagavideo.com
    October 2, 2011 at 12:45 am
    WOW, that’s less than an hour…Anyway, in AE this will work for sure.
  • Rafael Amador
    October 3, 2011 at 12:20 pm
    [Christian Schumacher] “WOW, that’s less than an hour”
    For a Video NLE and for when QT was designed, 45 minutes Stills Sequences is not too bad.
    Even being able to manage a higher number, I see it very little recommendable.
    If the advantage of the sequences is that you can treat/replace individual stills, chopping and compounding sequences is something natural.
    rafael
