Activity › Forums › Adobe After Effects › Problem with image pixels in After Effects!
Keith Mcgregor replied 14 years, 1 month ago 4 Members · 13 Replies
George Tsirogiannis
August 16, 2012 at 5:21 pmscratch that. you couldn’t pic whip it because your square comp would go into the negatives and scale up again. but you could dissolve it in at a point. and you would also want to do your scaling and positioning on a null and parent the square comp and your image to the null. We tried the draft quality with key frames and it looked smooth on our end. could you possibly have your keyframes set wrong?
I’m not sure I understood what you wrote. What square comp(if you mean the original composition, ok, otherwise i didn’t understand, not a native speaker or into the terminology!) I’ll try this with the null. I don’t think I’ve made any mistake with the keyframes though.
Thank you both for your time! I may seem to counteract to your responses but it’s nothing like that! 🙂
George Tsirogiannis
August 16, 2012 at 5:28 pmWow, in the end I understand, but it seems like the posts don’t appear correctly. Creative Cow, please stop this moderation, there’s no need to do this, it only confuses the discussion. 😛
Keith Mcgregor
August 16, 2012 at 8:05 pmIf you precomp and set to draft, then open the comp settings (cmd+K), choose advanced and check “Preserve resolution when nested” does that work? I think AE is trying to give you a clean image when you scale it up but you don’t want it to.
-KeithReality? What did you make it?
