Activity › Forums › Video Copilot › Problem with Illustrator Paths
  • Problem with Illustrator Paths
    Posted by Joseph W. bourke on December 4, 2015 at 7:57 pm
    I know I’ve run into this before, and I know there’s a simple solution to it, but I can’t for the life of me find it.
    When I copy the paths from Illustrator and paste into a new solid mask in AE, I get a “bounding box” which makes the Element 3D extruded text show up inside a small window in the middle of my 1920 x 1080 comp.
    I thought that there might be a problem with the AI file, that maybe there was some kind of cropping set, but that wasn’t it. Even when I create a new file in Illustrator and copy the paths, I get the same result in Element 3D. This is driving me nuts!
    Thanks for any help you can give.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
    Kalleheikki Kannisto replied 10 years, 9 months ago 2 Members · 5 Replies
  • Kalleheikki Kannisto
    December 6, 2015 at 7:56 am
    Don’t put the mask on the same layer as Element. Create a new solid for it and pick that other layer as a custom mask from your Element layer.
    Element gets confused about layer bounds if you add masks directly on the same layer, so any masking should be done on a separate layer. For the same reason, if you actually wanted to mask something off on an element layer, it should be done with a track matte, not with a mask.
  • Joseph W. bourke
    December 12, 2015 at 4:49 pm
    The mask isn’t on the same layer as element – it’s on a solid layer, then set up to be a custom layer in Element, applied to a new layer. So there are two discreet layers, one with the mask, one with Element 3D, the way it’s supposed to be done.
    Joe Bourke
    Bourke Media
    December 13, 2015 at 6:42 pm
    That’s weird. Do the masks fall within the solid area?
  • Joseph W. bourke
    December 16, 2015 at 4:17 am
    Yes, they do. For example, I might be working within a 1920 x 1080 comp, and when I create the new solid for the masks (same size), I end up with a “window” in the center of the comp, which is probably a quarter to a sixth the size of the comp, but the Element 3D model is the proper size to fit the 1920 x 1080 comp.
    My solution has been to size up the paths I’m copying from Illustrator; actually to size up the page size to larger than 1920 x 1080. Now this should not have any effect on things, since a vector is a vector, but it seems to work when I paste the masks into the AE solid layer. It’s just strange. I think the problem may be on the Illustrator side. I’ve got some more experimentation to do on this.
    Joe Bourke
    Bourke Media
    December 16, 2015 at 2:15 pm
    I’d suspect it is an Illustrator issue rather than AE. Are you on CC15? Can you upload a sample AI file that creates this problem for you, I can see it it works at my end?
