Activity › Forums › Apple OS X › Problem With IDVD Launching
Posted by Patrick Morrow on August 14, 2007 at 1:23 amIt just starts and then quits. Please help!!!
Patrick MorrowAztarheel replied 19 years ago 4 Members · 3 Replies -
Tony! Hulette
August 19, 2007 at 5:03 pmApple posted a solution to this problem. It has to do with old themes and offers a fairly easy fix.
https://docs.info.apple.com/article.html?artnum=306290
iDVD ’08: The application may unexpectedly quit when opened for the first time
IssueiDVD ’08 may unexpectedly quit when opened for the first time, after installation.
Affected products:
iDVD ’08
SolutionHave your iLife ’08 installation disc nearby before performing the following steps.
Erase the following folders from your hard drive:
/Library/Application Support/iDVD/Themes/iDVD 1
/Library/Application Support/iDVD/Themes/iDVD 2
/Library/Application Support/iDVD/Themes/iDVD 3
/Library/Application Support/iDVD/Themes/iDVD 4Erase the following folder from your home directory:
~/Library/Application Support/iDVD/Installed Themes
Note: The tilde (~) represents your home directory.Reopen iDVD ’08.
To Reinstall Themes 1-4:Open iDVD ’08 and open a project.
Click Themes.
From the Themes drop-down menu, choose Old Themes.
Select any of the faded-out theme thumbnails.
Follow the on-screen instructions to install all of the themes originally erased via Software Update or the iLife ’08 installation process.I hope that helps you and anyone else experiencing this problem (happened to me as well).
Tony!
Aztarheel
September 7, 2007 at 7:22 amBLESS YOU! iDVD 8 quickly flashing on and off was driving me nuts! Now, if only you could make me LIKE the new iMovie/iDVD. . . .
