Activity Forums Maxon Cinema 4D Problem with huge objects in viewport.
  • Problem with huge objects in viewport.
    Posted by Andrew Shishkin on May 19, 2011 at 8:35 am
    Object is 1500000m radius sphere. I cant see it in wiewport, only after render or if I set display method of viewport to lines. I tried to use software shading and opengl as well – same result.
    Is there a way to make it visible in viewport with Gouraud shading display method?
    Adam Trachtenberg replied 15 years, 3 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    May 19, 2011 at 4:02 pm
    Seems to be an OpenGL limitation. Turn off OGL in preferences and you should see the object.
    Out of curiousity, why in the world do you need such a large object?
  • Andrew Shishkin
    May 20, 2011 at 7:23 am
    I tried to turn off openGL and use software shading, but it doesnt helps.
    I need such big objects in scene to show sun scale to Earth (it is 109 times bigger).
  • Adam Trachtenberg
    May 20, 2011 at 11:36 pm
    You know that you could just scale the sun object down and *say* it’s bigger, right? 😉
