Activity Forums VEGAS Pro Problem with Heroglyph 4.0 in SONY VEGAS 12 – 64 bits
  • Problem with Heroglyph 4.0 in SONY VEGAS 12 – 64 bits
    Posted by Xavier Dolz on July 5, 2013 at 2:55 am
    Hello there,
    I’m testing Heroglyph 4.0 in SONY VEGAS 12, and the plugin seems to be quite simple to understand, however I am having a problem that is driving me mad. If someone here deal with Heroglyph, I would really appreciate his/her help.
    Well the problem is the following.
    Let’s imagine I want to apply a script effect. Okay, I apply one of the script effects it has by default, and I jump to the heroglyph timeline.
    Okay, I can set up the fade-in time. Perfect.
    I can set up the duration time, perfect, everything is fine here…
    I can set up the fade-out time, great…
    BUT!
    And here is the problem…
    When I set-up the start time of the effect to a value different than zero, I lose the fade out effect, and the text is always present in the screen.
    Inside the heroglyph timeline, everything is fine (this problem happen also when I play the clip in VEGAS). If I press play, I see the clip, I see the fade in effect and also I see the fade out effect without any problems. But when I apply the title to send it to VEGAS, I am not able to see the fade out effect and the text is always present, never vanish.
    So let’s imagine I have in VEGAS a time line of 20 seconds.
    And let’s imagine in Heroglyph 4.0 I have a script text, which duration (Range) is 8,50 seconds.
    If I make it start in at 0:00 seconds, that is in the beginning of the timeline, then everything is fine, I can see the fade in effect and the fade out effect. If I apply these settings and send the changes to VEGAS, everything works fine. I am able to see the fade in and fade out effect in VEGAS.
    The problem is when I tell Heroglyph to start the text in a value different than zero seconds.
    If I tell Heroglyph to start the script text in a value different than zero, for example, let’s say I want the text start at 2:00 seconds, then I cannot see the fade out effect (in VEGAS).
    Inside the Heroglyph time line yes, if I press play, there everything works fine and I can see both effects perfectly, but when I apply these settings to the title and I go to the VEGAS timeline, there I only can see the fade in effect, the text and… not the fade out effect.
    I realize this problem could be a bit confusing, if you don’t understand what I mean I could try to upload a video and show you?
    I am really desperate with this silly error. I really would appreciate your help.
    Steve Rhoden replied 13 years, 2 months ago 2 Members · 1 Reply
  • Steve Rhoden
    July 6, 2013 at 12:28 am
    I would also in the meantime recommend you make this same detailed
    issue you are having to Prodad support, they are very prompt in fixing
    problematic issues with their software.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
