Activity Forums Adobe Encore DVD Problem with HCenc and DVD authoring
  • Problem with HCenc and DVD authoring
    Posted by Carlos Angeli on May 14, 2013 at 3:00 pm
    Hi, I’ve been following Jeff Bellune’s tutorial on how to encode hd to sd footage, and then using HCenc v0.25 to input an avs file and output it as a suitable mpeg2 file for Encore DVD.
    The thing is that now HCenc freezes when selecting the avs file. It’s been working flawlessly until now so I have no clue of what’s going on. The only workaround I found is using HCenc v0.23 with a YV12 .avi file.
    With HCenc v0.25 I could use a YUY2 avi file.
    Any thoughts on how to fix HCenc or an alternative compatible with Encore DVD?
    Carlos Angeli replied 13 years, 4 months ago 2 Members · 2 Replies
  • Jeff Bellune
    May 14, 2013 at 3:41 pm
    What’s in your .avs script?
    Do you get good quality output from v0.23? If so, I recommend you just go ahead and use that.
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Carlos Angeli
    May 14, 2013 at 4:07 pm
    Hi Jeff,
    the script reads:
    AVISource(“720p.avi”)
    I just use it to open the avi file and export it to mpgeg2.
    Previous to that, I’m using a script that reads:
    SetMTMode(2,0)
    MPEG2Source(“Trailer1080p.d2v”)
    hd2sd(interlaced=false,OutputColorSpace=”YUY2″)
    V0.23 gives me a goo quality too, but I have to export the avi with YV12 (lagarith lossless config.) instead of YUY2, since YUY2 support was introduced in v0.25.
