Activity Forums Maxon Cinema 4D problem with Half circle and rounding
  • problem with Half circle and rounding
    Posted by Jason Yardley on June 19, 2012 at 10:27 pm
    I’m using the Cap and fillet on a piece of text, I’ve applied the R1 and C1 to the text with different materials, I’m ok on the C1 material but on the R1 I’ve added a half circle with a radius 1 on the fillet cap
    but the round circle over laps on certain letters i.e the M and the R I’ve posted a image up does anybody know how to get rid of this.
    Brian Jones replied 14 years, 2 months ago 2 Members · 3 Replies
  • Brian Jones
    June 19, 2012 at 11:56 pm
    try checking Constrain in the ExtrudeNurb
  • Jason Yardley
    June 20, 2012 at 7:57 am
    Yea have tried that but shrinks down the typeface a hell of lot, doesn’t look like the same typeface
  • Brian Jones
    June 20, 2012 at 3:16 pm
    yeah, but it’s not the font you started with since it’s making it all bigger to fit the fillet in but that makes areas where the splines are close (the spots in the R and M) actually cross over as they move outward so you get your artifacts. You either have to Constrain or ditch fillet all together and make your own ‘half-circle’ by using a copy of the text spline that’s being extruded and Sweep your own circle down that
