Activity Forums Maxon Cinema 4D problem with hair thickness map..
  • problem with hair thickness map..
    Posted by Jay Dunn on November 14, 2012 at 8:55 am
    I’m trying to make some lines trail off an object using the hair module. I want the thickness of the hairs to fade in and out (left to right) to give the illusion of movement, but I’m having a problem pluging a noise texture into my hair. It works fine when my hair runs perfectly straight along the Z axis, but when the hairs bend, everything gets messed up. I can’t figure out how to push a streaky noise map through the thickness attribute. (I believe it has to do the way my noise is mapped onto the hair).
    In the example below, i show my animation how i like it, and then I throw in some turbulence at the end, which bends my hairs and then my thickness attribute goes all nuts.
    desired look:
    undesired result when hairs bend:
    project:
    https://dl.dropbox.com/u/60060557/c4d/green_hair_01.c4d
    video clip
    https://dl.dropbox.com/u/60060557/c4d/preview31b.mov
    Jay Dunn replied 13 years, 9 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    November 14, 2012 at 4:07 pm
    Try setting the Texture space in the noise shader to UV (2D).
  • Jay Dunn
    November 14, 2012 at 6:22 pm
    ok well that works, but then I lose the left to right streaky movement along the profile of the hairs. I’d like for the hairs to be tapered and slide along the hair splines. When i change the texture space to UV (2D), the movement attribute becomes deactivated.
    I can use animate noise, but that changes the hair thickness globally along the entire length of the hair, so i lose my tapered left to right look.
    clip: https://dl.dropbox.com/u/60060557/c4d/preview5web.mov
    project: https://dl.dropbox.com/u/60060557/c4d/green_hair_02.c4d
