Activity Forums Adobe After Effects Problem with Gradient Color Change When Import from Illustrator to After Effects
  • Problem with Gradient Color Change When Import from Illustrator to After Effects
    Posted by Eric Olson on May 11, 2009 at 8:19 pm
    Hey Everyone,
    I’m having a problem importing some vector graphics created in Illustrator into After Effects. Some of the gradients are changing from color to white (can download jpg here https://www.sendspace.com/file/97cl4a to see what I’m talking about.) Tried changing around the color space but it didn’t work.
    Any ideas?
    Eric
    Eric Olson replied 17 years, 4 months ago 2 Members · 4 Replies
  • Adolfo Rozenfeld
    May 12, 2009 at 6:13 am
    Wouldn’t it be possible to post the AI file instead of a JPEG? That way I could take a look and see what’s going on.
    Adolfo Rozenfeld · Adobe
  • Eric Olson
    May 12, 2009 at 9:42 am
    I already changed the gradients in the pig illustration I posted before but here is another one that I’m having problems with. The “nose” and eyebrows of the pig are coming out white.
    https://www.sendspace.com/file/jdwv2k
    Eric
  • Adolfo Rozenfeld
    May 12, 2009 at 10:50 pm
    Hello, Eric.
    It was a tricky one, but I think I figured it out (of course, it’s human nature to consider the app is “broken” and I was very close to reaching that conclusion!).
    It turns out, one of the color stops in each of these gradients was set to use a spot color (Pantone) instead of a process (RGB) color. And of course, one shouldn’t blame AE for not handling inks, right? 🙂
    If you edit each of these gradient stops so they use process colors, there will be a very slight shift but then it will render identically in AE.
  • Eric Olson
    May 13, 2009 at 8:37 am
    Wow, that was a tricky one. I’ll give it a try. I had never used the Pantone colors before but I thought they were just a set of colors rather than being a different types of color.
    Thanks for your help!
    Eric
