Activity › Forums › Apple Final Cut Pro Legacy › Problem with frame rates, maybe?
Posted by Gerry Condez on January 9, 2015 at 6:30 pmHi guys, a studio friend using final cut 6.0.6, gave them clips from two cameras, from 60d and 70d.
They said frames rates are different, one is 29.97 and 23.98. Project is finished and plays on timeline, but have problems when they export the project. Is there a work around with this situation?
Please let us know your opinion or advice. Thank you.Shane Ross replied 11 years, 8 months ago 2 Members · 4 Replies -
Shane Ross
January 9, 2015 at 8:16 pmWhat are the problems when you try to export? Did you convert the footage to ProRes before editing?
What is the frame rate of the sequence? What frame rate do you want to export? Where will this be viewed?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Gerry Condez
January 9, 2015 at 8:18 pmOh, that stinks.
Isnt it that all clips get converted upon importing the files? Is there a conform function in fcp? Im tying to help and i use a totally different editing software, just so happen the project is 3 hours long and his deadline is tomorrow. Thanks again. -
Gerry Condez
January 9, 2015 at 8:54 pmThanks Shane, just spoke with him and said he had general errors when he exported file. So far, he managed to do some work around with the problem. Anyway, i send him the link to this post so he can continue on incase he get stuck.
I appreciate all the help from all of you here. Thank you -
Shane Ross
January 9, 2015 at 11:59 pm[Gerry Condez] “Isnt it that all clips get converted upon importing the files?”
If you use Log and Transfer, and set in the preferences the format that they are to be converted to (ProREs 422, ProRes HQ), FCP will convert the codec…it’ll convert the footage to ProRes. But FCP never converts the frame rate. But Log and Transfer doesn’t work with those cameras, as they came out after FCP was discontinued. And you are working with an even OLDER version of FCP
If you simply IMPORTED the footage…FCP doesn’t convert at all. It makes clips that point to the media as it exists. So if you have QT files from Canon DSLRs, and you just IMPORTED them…no conversion was done at all And FCP doesn’t work well at all with the format those camera’s record…H.264. That leads to all sorts of issues….sync issues, general errors, exporting problems. So if you simply imported H.264 footage, in mixed frame rates…yeah, you have painted yourself into a really big corner. One that will take days to straighten out.
First off, you’ll need to figure out what frame rate you want to master as…what frame rate you want to be the main frame rate. And then you’ll need to convert the footage to that frame rate. But because your show is already edited…this will have to be done in very specific ways to retain the edit. And know that converting any progressive frame rate to another progressive frame rate won’t look smooth. So i even wonder if converting the frame rate in another app would make any difference in how it looks. It’ll look stuttery no matter what you do.
[Gerry Condez] “Is there a conform function in fcp?”
There’s a Media Manager…that will convert the footage on your sequence to another codec. But it does nothing to the frame rate.
[Gerry Condez] ” just so happen the project is 3 hours long and his deadline is tomorrow. “
You’ll not make that deadline. I agree with David…this will take days to solve. and you’ll need to find an FCP expert to do it. This is something that’s too big to explain in a forum.
Shane
Little Frog Post
