Activity Forums Adobe Premiere Pro Problem with FPS and audio
  • Problem with FPS and audio
    Posted by Daniel Hvilsted on July 30, 2009 at 1:35 am
    Hey
    I’m new to the Adobe programs.
    After making a perfect 2½ minutes movie clip I went to sleep..
    But the following morning, when I loaded the project to Export it..
    One of the video clips was changed…properly something I’ve done wrong but what..?
    The FPS was dropped to 0,3330 and the audio was gone..
    I tried to delete the Media Cache Files and let Premiere Pro do the job (reconforming the files..) Then the sound came back.. Weee 🙂
    Then I changed the FSP back with Interpret footage to 29;97 FPS.. But.. then the audio suddenly disapired again…. Replace Footage doesn’t help
    The problem just keep looping from no audio to low FPS… but why..?
    Please help me 🙂
    Daniel
    Jon Barrie replied 17 years, 1 month ago 3 Members · 3 Replies
  • Brian Louis
    July 30, 2009 at 7:02 pm
    You should mention what type of source footage you are using, and what presets you are using
  • Daniel Hvilsted
    July 31, 2009 at 10:24 am
    Source footage is;
    2 x HDV MPEG4 from video cam. (1920×1080)
    Type: XDCAM-EX Movie
    File Size: 61,8 MB
    Image Size: 1920 x 1080
    Pixel Depth: 32
    Frame Rate: 24,98
    Source Audio Format: 48000 Hz – compressed – Stereo
    Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
    Total Duration: 00;00;29;13
    Average Data Rate: 2,1 MB / second
    Pixel Aspect Ratio: 1,0
    1 x VOB converted to MPEG4 (720×576) – The troublemaker…
    File Size: 251,7 MB
    Image Size: 720 x 576
    Pixel Depth: 32
    Frame Rate: 0,33
    Total Duration: 15;34;13;18
    Average Data Rate: 1 KB / second
    Pixel Aspect Ratio: 1,094
    The projekt is runnning in
    1440 x 1080
    00;38;53;07, 25,00 fps
    48000 Hz – Stereo
    With the 720×576 MPEG4 I pressed scaled to Frame size and made some effects like old television shows so it fit the frame size from the 720×576..
    I was very happy 🙂 😀
    But.. now it’s a nightmare
    I can recall the problem started as PP was conforming the 720×576 file and it falied because my diskspace was low
    Then the FPS and audio problems started..
    Daniel
  • Jon Barrie
    July 31, 2009 at 12:56 pm
    Have you tried:
    unlink the file.
    Save and close the project.
    Quit Premiere Pro.
    Rename the file by adding a _ at the end of the name.
    Launch PPro.
    OPen the project.
    relink the clip with the new name.
    Hopefully this will reconform and index the file.
    Don’t touch the computer until it’s finished doing the indexing and conforming.
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
