Activity Forums Apple Final Cut Pro Legacy Problem with FCP 5.1 & Firewire control with JVC-GYDV5000
  • Problem with FCP 5.1 & Firewire control with JVC-GYDV5000
    Posted by Southeastvideo on April 17, 2006 at 10:30 pm
    I sure hope someone out there can help me out. I’ve just up-graded to FCP 5.1 from 4.5HD. My deck went down prior to the upgrade and I have been using my JVC GY-DV5000 as a temporary deck. However now that I am with 5.1 I am having device issues. My projects are in DV NTSC and the camera is in the vtr mode. While tring to capture the preview is disabled but I can control the camera with the log and capture window. I even see timecode coming through just no picture, only color bars with preview disabled. It’s like its not getting a 100% of the firewire feed.
    Has anybody else tried to use this camera with FCP 5.1 and had issues? Any help would be greatly appreciated.
    Patsy Northcutt replied 19 years, 12 months ago 3 Members · 3 Replies
  • K Albright
    May 2, 2006 at 2:48 pm
    Hi there. I had this same problem as of yesterday. I’m using a Cannon Z100 as a deck and have a new imac duo. I ‘fixed’ the problem by switching firewire ports. Not sure that I like that ‘fix’ (as it implies there is something wrong with the other port and the machine is new) but that’s what I did and it works now.
    I’ve been reading up on this and see this problem posted quite a bit, although not a lot of solutions. One other I did see was to reinstall Quicktime, but you need to trash some library files first.
    Good luck – frustrating problem. Hope you got it solved already!
    K
  • Southeastvideo
    May 2, 2006 at 8:46 pm
    Hey thanks for the reply and support. I did re-install Quicktime and it fixed the problem, however I did not trash any Library files. But like I said it seems to be capturing fine. Should I be worried having not trased any library files?
    Thanks for your time.
    Robert Bonner
  • Patsy Northcutt
    September 7, 2006 at 10:26 pm
    I just encountered a variation of this problem and fixed it by moving the FW400 cable to my deck to the front port on my G5. Thanks for the suggestion!
    Director/Producer/Editor
    Northcutt Productions
