Activity Forums Apple OS X Problem with Extended Desktop on Powerbook
  • Problem with Extended Desktop on Powerbook
    Posted by Jonathan Lê on August 10, 2005 at 4:38 pm
    I’m having problems using a 17inch crt monitor with my Powerbook. I’d like to use it for an extended desktop but whenever I use that option in System Pref>Displays my crt goes wonky. Using the mirror function works just fine. Is this a resolution issue where the CRT can’t keep up with the LCD on the Powerbook and if so can I not somehow adjust the resolution settings separately?
    Thanks in advance
    Jonathan
    Jonathan Lê replied 21 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
