Activity › Forums › Adobe Premiere Pro › Problem with exporting XML from Premiere
  • Problem with exporting XML from Premiere
    Posted by Marko Ristić on May 19, 2017 at 10:26 am
    Hi!
    I have a problem exporting project from Premiere to Final cut. Every time i try to export i get this report :
    Sequence at 00:00:00:00, audio track 9: Effect on Clip not translated.
    Translation issue:
    Sequence at 00:00:34:09, audio track 1: Transition not translated, Cross Fade ( 0db) used instead.
    Translation issue:
    Sequence at 00:00:36:17, audio track 6: Effect on Clip not translated.
    Translation issue:
    Sequence at 00:00:42:18, audio track 7: Transition not translated, Cross Fade ( 0db) used instead.
    Translation issue:
    Sequence at 00:00:46:17, audio track 6: Effect on Clip not translated.
    Translation issue:
    Sequence at 00:01:46:00, audio track 8: Effect on Clip not translated.
    Translation issue:
    Sequence at 00:02:15:05, audio track 6: Effect on Clip not translated.
    and so on…
    So i tried to make a workaround. I rendered all the tracks in wav. and that worked. But the problem is, that is not entirely something that my client wants.
    The only ”effect” expect one Expontial Fade that i had, is basically just animating sound levels on different audio files in the project.
    Is it possible that XML cannot translate this very simple effects ? Does somebody has similar experience and is there a solution to this problem?
    Also i tried 3 different version of Premiere; CS6 CC2014 and CC2017 the same thing.
    Peter Garaway replied 9 years, 4 months ago 3 Members · 3 Replies
