Activity Forums Adobe Premiere Pro Problem with exporting to quicktime
  • Problem with exporting to quicktime
    Posted by Ryan Santos on January 8, 2007 at 11:48 pm
    Using Adobe Media Encoder, I can export my project to .flv without any problem. However, when exporting to quicktime, my video’s speed is fast (as if played in fast-forward mode) while the audio’s speed is normal. What could be the problem? Thanks.
    Ryan Santos replied 19 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Blast1
    January 9, 2007 at 12:16 pm
    [Ryan Santos] “What could be the problem?”
    Before someone can give you any insight you should, describe your project’s settings and what settings you are trying to export otherwise you will get WAGs.
  • Harm Millaard
    January 9, 2007 at 1:00 pm
    Blast, what is a WAG? Shorthand for Widely Alternating Gossip?
  • Mike Velte
    January 9, 2007 at 3:10 pm
    ROFL! BTW Harm, without an emotion in your question to Blast, one must assume you are serious.
    Just a Wild A** Guess {-;
  • Harm Millaard
    January 9, 2007 at 3:56 pm
    Thanks Mike,
    Indeed I seriously did not know, hence my question.
    I keep learning every day here, if not video related, than at least language related.
    “Time is a great teacher, but unfortunately it kills all its pupils.”
  • Ryan Santos
    January 10, 2007 at 5:35 am
    It’s actually a video I shot with a consumer camera (miniDV) at 720 x 480 and I wish to have it in quicktime at 600 x 432 (or a bit smaller). I don’t know what settings I should use but the output should look and sound good when published to the web… and of course something that’s light enough for easy downloads.
  • Mike Velte
    January 10, 2007 at 12:41 pm
    The only decent QT export option from Premiere 2 is H 264 (mpeg4) and that requires the audience have QT player 7.x. There is no preset for this, so open the default QT Format/preset in the Media Encoder. On the lower left side are some tabs, start with Video. Change the Video Codec to H.264, change your Frame height and Width. scroll down and change the Bitrate to 600 kbps.
    On the Audio tab, leave the default QDesign Music 2, but click the Options button and change the bitrate to 48 kbp/s.
    I prefer to use QT Pro to do this encoding…many more options and better quality. Although I use Windows Media Video most of the time.
  • Ryan Santos
    January 20, 2007 at 4:11 am
    Thanks Mike!
