Activity Forums Adobe Premiere Pro Problem with ‘Export To Movie on Premiere Pro’. Help!
  • Problem with ‘Export To Movie on Premiere Pro’. Help!
    Posted by Lanzi on May 30, 2005 at 10:57 am
    Goodmorning and Greetings.
    I have an ‘Export To Movie’ problem with Premiere Pro 1.5. I am exporting a DV PAL 83 minutes footage onto a Lacie external drive. 30GB free space which is enough. After say 15 minutes of exporting (at best quality settings) I get: ‘Disk is full’ message. If I export the movie as 6 seperate clips then I have no problmes. It all fits in the Lacie. But I need to have a continous 83 minute final clip to then burn on DVD via Adobe Encore.
    Please help. How can I solve this painstaking problem?
    Warmest Regards,
    Lanzi
    Lanzi replied 21 years, 3 months ago 4 Members · 5 Replies
  • Mike Velte
    May 30, 2005 at 11:29 am
    Suspect that your external drive is formatted as FAT32 which would limit a DV file to 18 minutes (4 gb). Format it as NTSF.
    https://www.video2stream.com
  • Lanzi
    May 30, 2005 at 11:39 am
    Thanks for reply. Yes it is FAT32. I just learnt all about FAT32 vs NFTS 1 hour ago. My knowledge of system is poor am afraid. If I format I will lose the information in it. I learnt about AVisynth but really confused on how to open a script editor to paste clips together. Can you expand more on your adivice and perhaps on Avisynth?
    Thank you.
  • Andre Gagnon
    May 30, 2005 at 6:55 pm
    [Lanzi] “If I format I will lose the information in it”
    It is not a real format. You will not lose anything if you do it. Make a search for the “Convert” function in your OS Help. It is a very quick and harmless operation.
  • Blast1
    May 31, 2005 at 6:30 am
    Just to add a bit of information, the Convert program is located in the System32 folder, here is a MS knowledgebase article on using Convert: https://support.microsoft.com/default.aspx?scid=kb;en-us;314097
  • Lanzi
    May 31, 2005 at 1:56 pm
    PROBLEM SOLVED.
    In the end I backed up my data on Mac and reformatted to NTFS on PC (my premiere is on PC).
    No 4 gig limit during export now. Thanks a bunch to all. The Convert option is a good tip.
