Problem with Event FX
Posted by Zach Desmond on February 16, 2009 at 5:17 pmHi, usually when I add and Event FX to a clip, a window pops up that allows me to edit the FX.
However that window no longer pops up for me. Is there any way to make the window appear again?
Thanks.
Zach Desmond replied 17 years, 6 months ago 3 Members · 9 Replies -
Rob Strobbe
February 16, 2009 at 10:03 pmIt is probably either:
a) docked into one of the various window docking areas. Check among your Video FX, Media Generator, etc windows. All of the dockable windows (including the Video Event FX window) have a vertical line of six dots in the upper left corner; click and drag that line to undock the window.
b) undocked and floating somewhere you can’t see it. Maybe on another monitor if you have more than one or way at the bottom of the screen hiding under your Windows taskbar. You can click and drag the top edge of the taskbar down to see if your FX window is under there.
Rob
Danny Hays
February 17, 2009 at 1:46 pmSometimes a window gets hidden off the monitor, if it’s a secondary monitor, you can deselect “extend desktop to this monitor” temporarly
to get it back in the primary monitor, then re-enable the second monitor. If it’s off the edge of the primary monitor, you can temp change the resoultion to get it back in view. Hope this helps, Danny Hays -
Zach Desmond
February 17, 2009 at 8:07 pmThanks for the replys, but unfortunately they didn’t work.
I messed around with the resolution for a while but the Window never appeared.
I also don’t have any secondary window option enabled, so that didn’t work either.
Danny Hays
February 17, 2009 at 8:48 pmTry holding down ctrl + shift while launching Vegas. This resets all the settings to default settings.
Zach Desmond
February 18, 2009 at 2:13 amWow, I thought for sure that would work. Thanks for the great advice but that did not work either.
Danny Hays
February 18, 2009 at 10:48 amLooks like you need a reinstall. Uninstall and delete the Sony Vegas folder, then reinstall. Danny Hays
Zach Desmond
February 18, 2009 at 8:43 pmEdit: Oh sorry, I had to choose the order by phone option. THanks so much for your help Danny Hays!
Danny Hays
February 18, 2009 at 8:55 pmSo it let you enter your serial number right? Does the effects window show up now?
Zach Desmond
February 19, 2009 at 1:30 amYes it did, and the event window shwos up perfectly. Thank you again. 🙂
