Activity › Forums › VEGAS Pro › Problem with editing window for vegas
  • Problem with editing window for vegas
    Posted by Joseph Losing on March 5, 2011 at 12:26 am
    When I drag or select an effect in vegas, no window pops up allowing me to customize the effect. This causes it to be virtually impossible to edit beyond a very elementary level. Can anyone help? Why is the option not popping up? Is it somewhere else?
    Thanks.
    P.S. Vegas pro 10.0
    Anthony Johnson replied 13 years, 4 months ago 6 Members · 5 Replies
  • Steve Rhoden
    March 5, 2011 at 2:06 am
    Go to view, then Windows Layouts and click Default Layout to try
    to reset your window layouts and see if things return to normal.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
  • Graham Bernard
    March 5, 2011 at 6:39 am
    Steve, will the Default Layout option produce the same result – viz Windows Layout – as the Factory reset?
    Grazie
  • Matt Crowley
    March 5, 2011 at 10:57 am
    Default Layout returns window positions to the factory defaults – I think it’s the same as Factory Reset but only affects window positions/docking.
    However, it won’t get your effects window back if you mistakenly dragged it outside the Vegas window or under the taskbar. Try unlocking and collapsing your taskbar (right-click on taskbar, uncheck the Unlock option, then drag the top edge of the taskbar down so it collapses to a thin line. Reverse this process when you’re done) and looking for the effects window there.
    This might also happen if you change desktop resolution during editing.
  • Márcio Nascimento
    March 10, 2011 at 1:40 pm
    Thanks Matt,
    Yesterday I´ve reinstall Vegas to try resolve this “bug”
    Believe me, even if you reinstall Vegas, the windows dropped out of the Vegas window continue out there!
    My VideoFX and Ultimate were under the taskbar.
    Márcio Nascimento
    – Editor, cinegrafista e fotógrafo –
  • Anthony Johnson
    May 28, 2013 at 10:56 pm
    the best soloution yett to a irritating problem
    many thank
    a happier sony vegas 12 pro user
