Activity Forums Adobe After Effects Problem with displacement maps
  • Problem with displacement maps
    Posted by Bausdtown on June 19, 2006 at 4:19 pm
    I have a problem with rendering out a composition (HD), using displacement maps.
    Our composition is made of a precomp of solid layers in pink (stripes), and green (background-layer in comp size).
    I added displacement-maps, using another precomp.
    Depending on the setup of my rendering process, the results differ, but they never look as intended (smooth curves).
    The edges of the curves are allways kind of jittery, an not really smooth, sometimes it seems like there’s some kind of black line on the edges (which isn’t).
    I rendered out some screenshots, so you can see (hope, the links work):
    The Displacement-Map:
    https://www.flickr.com/photos/94658652@N00/170553685/
    The Result:
    https://www.flickr.com/photos/94658652@N00/170553683/
    A small part of the result in 100%, so you can see the problem:
    https://www.flickr.com/photos/94658652@N00/170556651/
    When I rendered the composition out as a PAL-Quicktime (Avid Meridian) there were strange white dots on the edges:
    https://www.flickr.com/photos/94658652@N00/170562572/
    When I rendered the composition out as a PAL-Quicktime (no Codec), in Quicktime it looked okay, but when I importet it in Avid the curves looked not smooth at all, more like a stairway step, if you know, what i mean.
    Has anyone an idea??
    No nation – no border!
    Fight Law & Order!
    Displacement-Map
    Peter Litwinowicz replied 20 years, 3 months ago 2 Members · 3 Replies
  • Peter Litwinowicz
    June 19, 2006 at 4:53 pm
    This is something we’ve experienced over the years with AE’s displacement map filter. basically, it has no filtering to prevent aliasing. Note also, that AE’s corner pinning filter also has this aliasing problem.
    In fact, we here at RE:Vision Effects often want to distort or displace things without this aliasing… so much so that we included a filter in our RE:Map product ($149.95) that does displacement mapping, but with all the filtering you need to prevent this aliasing. We’ve also included a corner pinning filter that also eliminates this aliasing (along with other bells and whistles). (and RE:Map has a couple of other filters which I will not go into here.. see https://www.revisionfx.com/rmap.htm ).
    I see that you posted the displacement map. Can you post the AE project with the displacement map filter applied (with the comp that creates the stripes, or the image with the stripes as a JPEG file)? If you have an AE project with animation of the displacement map, or the displacement amount, even better (because you will see aliasing much more clearly in the animated result..). Once I have that , I’ll make you a sample project that uses the demo version of RE:Map to show you how much better our filter is.
    Pete Litwinowicz
  • Bausdtown
    June 20, 2006 at 8:02 am
    Thanks.
    Heres the part of the project with the displacementmap:
    https://rapidshare.de/files/23567177/displace.aep.html
    Fight Law & Order!
  • Peter Litwinowicz
    June 20, 2006 at 10:02 pm
    So I posted a project here: https://www.revisionfx.com/tmp/displaceAndREMap.aep.zip . You’ll need to download the RE:Map demo installer (located here: https://www.revisionfx.com/rmapdownloads.htm ).
    In the Satz 10 comp, you’ll see there are 4 layers…. two of which are labeled “AE Displacement Map” and “REMap Displacement Map.” The AE Displacement Map’s visibility is turned off. Turn it on to compare our effect with AE’s.
    Some things to note: Since you are using a displacement amount of 50, it is advisable to have the project be in 16bpc… you’ll get much more precise displacments whether using our RE:Map or AE’s Displacement Map filter.
    Second: we do different things than AE’s filter if the displacement map and image-to-be-displaced are of different sizes. As such, I changed your displacement map to be 1920×1200 (it was originally 1920×1080) so that you could compare the results more directly.
    Third: I set RE:Map Displace’s Warp mode to Inverse (the equivalent of AE’s), and set the MaxDisplace (in the Displacement Controls grouping) to 50. Then, because we do our math a bit different than AE, I set the Vector Scale X and Y to -1 so that I could get the same results.
    Fourth: in order to turn on anti-aliasing, I set the Antialiasing Sampling to 3×3. This is the key to getting the better result than AE’s Displacement Map filter
    Last: we don’t currently offer a wrap-around edge behavior that AE has, so we have a slightly different edge than AE.
    Another thing: if you squash the image alot, you would want to set the Mip-Map method to something other than standard (you don’t need it for this project, but you might in the future).
    Let me know if you have any other questions,
    Pete LItwinowicz
